    Create Background Images
    16 Posts 11 Posters 39.4k Views 11 Watching
    • N Offline
      not registered yet
      Hi, there! I am going to show you how to create a background from your image! In this case, here is the image you want for your background, for example:
      Okay, open SketchUp and Go to Window > Styles. Next, click on the icon with the "ok" on it, which is the Watermark Settings icon. Then, click on the + sign. Find that image you want, then click "Open". Then choose from either "Background" or "Overlay". Both the same tutorial steps, you can change the transparency of the image with the model. Next choose "Stretched", "Tiled", or "Positioned". Click "Finish" when you're done. PRESTO! Example:
      Or with "Overlay".
      If you want to share your model with your background image, please upload it here! 😉 Have fun!
      poster-Invader ZIM
        Nice background, Invader!
        • KrisidiousK Offline
          Krisidious
          suddenly we have a contribution from the zimmer...
          and it's useful? holy crap... keep it up zim and I will change my vote...
          thanks for the Tut
          By: Kristoff Rand
          • K Offline
            kwistenbiebel
            Can we have support for the .png format again on the forum?
            Some threads like these (see first post) became just useless without it.
            Thanks in advance,
            Kwistenbiebel
              sketchy
              I second that.
                sketchy
                Thanks for fixing the png extension. You moderators are doing a great job 😍
                  sasrabirawa
                  is there any possibilities to use JPG format..??
                  Just an ordinary Sketchup user
                    AcesHigh
                    i dont see any icon with "ok" in it (inside styles)
                      You need to go to the Edit tab first:
                        JohanR
                        Very useful! 👍
                          Marwan
                          Thanx ... its realy useful
                          ____________________________________________________________________________ "[i:2c0yhog7][b:2c0yhog7]There is no god but He[/b:2c0yhog7][/i:2c0yhog7] : That is the witness of [b:2c0yhog7]God[/b:2c0yhog7], His angels, and those endued with knowledge, standing firm on justice. There is no god but He, the Exalted in Power, the Wise."
                          • N Offline
                            nocturnal_orion
                            it works but when i try to render it the background seems to vanish? i do everything but it always not visible when i render.. please help new here dont know wht to do..
                              Hi Cris,
                              What are you rendering it in?
                              In most external renderers (or built in plugins) you need to add the background differently (inside the rendering program).
                              • N Offline
                                nocturnal_orion
                                @gaieus said:
                                Hi Cris,
                                i used twilight renderer i think its plugins right? how can i add it inside the wilight program?? anyways thanks for replying.. i really need help..
                                  Well, in Twilight, it is here (below):
                                  If you use Twilight, you should really go to their forums as it is an extremely supportive forum and you can find lots of things (materials, models and even spherical backgrounds) there.
                                  Here are some (hemi-)spherical sky backgrounds for instance (the rectangular ones should be added as hemispherical).
                                  • O Offline
                                    ortzak
                                    Thanks guys..so this is how watermarks done!
