    Imperfect Sirkle
    15 Posts 5 Posters 10.5k Views 5 Watching
    • KrisidiousK
      Krisidious
      I was working on a dormer when I wanted to create some insulation. so I started creating my batting inside the exterior wall.
      as I started off I partition half of the space for a circle and wanted a center. made the cross... centered the circle. and afterwards the circle I end up with elongated... either way I do it. it's elongated the other way.
      I also tried changing the number of side on the circle.
      the units are set to 1/16" precision. arch format
      any ideas as to why it's an ellipse?
      By: Kristoff Rand
      • AnssiA
        Anssi
        What number of segments are you using? As the SU circle is always in the end a polygon, only a circle with a segment count divisible by 4 would fit exactly inside a square, with an endpoint touching each side.
        Anssi
        • KrisidiousK
          Krisidious
          I used 96 and still got the same output.
          By: Kristoff Rand
          • GaieusG
            I could not reproduce it either.
            • boofredlayB
              boofredlay
              Attach the skippy Kris.
              • KrisidiousK
                Krisidious
                attached...
                Dormer_II.skp
                By: Kristoff Rand
                • GaieusG
                  Chris,
                  I changed the units to centimetres (it's quite unconfortable for me to think in fractions of inches) with 4 decimal accuracy (I usually work with just 3).
                  See attatched image and redraw those squares. πŸ˜„
                  • boofredlayB
                    boofredlay
                    As I suspected... your square was not square.
                    Do as Gai suggested or better yet, draw a line on one side of the square, not inside the component. Then rotate it to the other side and you will see for sure that they don't match.
                    Sloppy Kris :esurp:
                    Just funnin' with you. :ewink:
                    • boofredlayB
                      boofredlay
                      See here:
                      DormerTest.skp
                      • GaieusG
                        Ah yeah, before any misunderstanding, the comma is used as a decimal separator in Hungary, not the dot.
                        • KrisidiousK
                          Krisidious
                          wow.. I swear I used the inferences to check the corners... and then the measurements seemed to confirm I had the right lengths.
                          good job guys. and a good point to remember, it's almost always human error. bugs are few and far between.
                          (we should leave this here for a few days so people can see it's compeltetion. and then remove it from the bugs list.)
                          By: Kristoff Rand
                          • KrisidiousK
                            Krisidious
                            and just to add... another thanks. it's like getting the cure for a disease when someone fixes your problem.
                            By: Kristoff Rand
                            • GaieusG
                              Welcome, Kris.
                              And I know how that is. And sometimes the solution is just there.
                              I couldn't get used to these "architectural" units of yours though... πŸ˜„
                              • KrisidiousK
                                Krisidious
                                as well you shouldn't get used to our imperial system... is archaic and irrational. 10 units of 1 and 0 that is the universal language, that... when and if ever we meet another life form, from another place, will be the language they know.
                                By: Kristoff Rand
                                • TIGT
                                  UNLESS they have 16 fingers ? Then it'd be in Hexadecimal... But it's true that on/off 1/0 binary is the simplest of all... Of course base 12 like feet/inches does have it's advantages - 1/2, 1/3, 1/4, 2/3 and 3/4 are all whole numbers - unlike metric/decimal where only 1/2 and assorted 1/10ths work... That's why long a go some one put 12 hours into the day and night and 360 degrees in a circle - 360 is a multiple of 12 and subdivides into lots of whole numbers - unlike gradians and radians...
