    Change color edges
    5 Posts 4 Posters 1.5k Views 4 Watching
    • N
      not registered yet
      Sorry for my english 😳 . I desire to be able to assign a color to an edge particularly. Not actually default global color edges change.
      (palyndrok)
      • boofredlayB
        boofredlay
        Go to your styles editor and change your edge style to "By Material" then start painting lines as you see fit. πŸ‘
        http://www.sketchucation.com/forums/scf/sas/ProUser/ByMaterial.jpg
        • EdsonE
          Edson
          eric,
          today i needed to paint one single line and came to the forum for this advice. i followed your suggestion but the problem is that by doing so ALL edges are affected. all i want is to change the color of ONE edge. how can i do it?
          http://www.mahfuz.arq.br
          • GaieusG
            Edson, just select that particular line (easier in wireframe for sure) and paint it with the appropriate colour. You still need to set the "color by material" line display.
            • boofredlayB
              boofredlay
              Edson, are all your lines changing color when you select By Material?
              If so then all your lines were already painted somehow.
              The only way to change this is to paint all your lines back to default and then paint only the lines you need. The best way to do that is to go to wireframe, select the lines and change their color via the Entity Info panel.
