    [Plugin] TIG_Slicer v7
    slicer
    25 Posts 6 Posters 556 Views 6 Watching
    • T
      TBoy
      SlicerSVG.zip
      SVG's not loading. Use these, edit with VectorCraft, it's free.
      TIGT 1 Reply Last reply
      • TIGT
        TIG Moderator @TBoy
        @TBoy
        SVGs work fine for me in newer versions of SketchUp ?
        What OS, what SketchUp version please ?
        • T
          TBoy
          v2020 on W10, I see toolbar with 4 empty buttons.. When I edit svg files I see just 1 scaled up, pixelated image layer of the old-png-icon inside svg. No vector drawing inside. (Toolbar name is still Slicer5)
          • TIGT
            I haven't tired it on a Windows or SketchUp version that old.
            If you icons work OK on my newer system I'll look at packaging them with an update...
            • TIGT
              Just tested your SVG alternatives and they do work fine on my newer versions too.
              They are also slightly sharper [but not very noticeably so].
              I'll package them with v7.2 RBZ and update the PluginStore's entry...
              I'll also update the MAC's PDF equivalents...
              • TIGT
                v7.3 will be published in the PluginStore / ExtensionStore shortly...
                It incorporates the better icons from @tboy and Slicer5 references are changed to Slicer7 in various places...
                https://sketchucation.com/pluginstore?pln=TIG_Slicer
                • A
                  AlejoRonny09 Newcomers @TIG
                  @TIG Hi Tig, I haven’t been able to load the extension in SketchUp; an error appears stating: "This file could not be identified as an extension. It cannot be loaded or updated. Uninstall the file and contact the developer for an update."
                  How can I resolve this?
                  • TIGT
                    I have tried installing it in several ways - they all work without errors.
                    More info from you first...
                    What OS, what version of SketchUp.
                    How are you trying to install it ?
                    There are two main ways, with subsets.
                    1. You use the SketchUcation toolset's ExtensionStore - find the extension's entry and auto-install it. No need to get an RBZ etc. Restart SketchUp afterwards to sync everything.
                    2. You downland its RBZ from the SketchUcation PluginStore...
                      2a. You use the Extensions > SketchUcation submenu item to install it from the archive [that works for RBZ & ZIP archives]. Restart SketchUp afterwards to sync everything.
                      2b. You use the native SketchUp Extension-Manager to Install the extension from its RBZ. Restart SketchUp afterwards to sync everything.
                      2c. You extract the contents of the RBZ [which is actually a ZIP file] into a temporary subfolder -
                      either change its suffix to .ZIP or set your 'Open with...' settings to let your Z-app process .RBZ files too.
                      Move the extracted contents - a Slicer.rb file and Slicer folder with all of its contents in tact -
                      into your Plugins folder [again there's an Extensions > SketchUcation submenu item to open that folder for you.
                    Which way are you trying ?
                    One thought - if your computer's Firewall is blocking downloads from SketchUcation's PluginStore you might end up with an 'empty' RBZ - what is its size ?
                    It should be about 75kB
                    • A
                      I have already tried both methods, and I also checked the firewall settings—everything looks fine. The file downloaded without any issues and has a size of 75 KB. I am using SketchUp version 2026 on Windows 11 Pro.
                      The same error keeps appearing.
                        Set you loading policy to not be so strict.
                        • TIGT
                          TIG Moderator @AlejoRonny09
                          @AlejoRonny09
                          If you are managing to download the RBZ and it's the expected 75kB size can you do the following...
                          Select the .RBZ file and right-click -Open with... In the list choose your normal Z-app - e.g. 7zip.exe. It should open and show the following...
                          Choose Extract and you should get a folder containing the Slicer.rb file and Slicer subfolder.
                          Close the RBZ.
                          Open your SketchUp's Plugins folder and copy those two into it.
                          Open SketchUp and report errors [if any].
                          If this persists then look in your Plugins folder and remove any 'Slicer' files and subfolder - also check there is no old 'TIG-Slicer' equivalents in there too. Then try repeating the copying over of the 'Slicer' file and its subfolder. Any better ?
                          • 2 / 2
