    [Plugin] ms Dims-O
    4 Posts 2 Posters 417 Views 2 Watching
      mihais
      ms Dims-O
      (v1.0.0)
      Description: ms Dims-O (O stands for Overlay) provides an elegant, real-time HUD (Heads-Up Display) for SketchUp 2023+. Using the new Overlay API, it instantly displays the X, Y, and Z dimensions of your selection.
      • Activate the extension (Extensions > ms Dims > Activate HUD, click on the icon or assign a shortcut);
      • Select geometry or an object (group, component) or several;
      • Information about the object dimensions appears on the screen in the lower right (you can change the position in Extensions > ms Dims-O > Settings).
      Key Features:
      • Automatic Detection: Shows dimensions for Geometry, Groups and Component Instances.
      • Scale Warning: The "Dimensions:" label turns RED if the selected object has been scaled, warning you that reported dimensions might not match the internal geometry.
      • Customizable: Change text size, label text, and position (4 corners) via the Settings menu.
      • Non-Intrusive: Works as a native Overlay that can be toggled on/off via the Overlays panel or the included toolbar.
      Installation:
      • Download the .rbz file;
      • In SketchUp, go to Extensions > Extension Manager;
      • Click Install Extension and select the downloaded file;
      • Ensure the extension is enabled in the Overlays panel (Tray).
      COMPATIBILITY:
      SketchUp 2023+
      AUTHOR: Gemini AI for ms
      LICENSE: GNU GPL
      Inspired by Qol Hud-Dimensions (Blender).
      Download: https://sketchucation.com/pluginstore?pln=ms_Dims_O
      YouTube:
        Thanks for the upload to the PluginStore/ExtensionStore.
        I have Published it for you, so it's now available to all users.
        I can see little to comment on - it works fine.
        Note that require 'sketchup.rb' etc is not needed in any of your code, because, unlike older versions, it's now auto-required at startup as SketchUp loads, before your scripts are considered.
          mihais
          Thank you, TIG!
          I will tell Google Gemini AI to take your information into account for future extensions.
          Have a nice day!
            The 'require' code that is unneeded doesn't break anything, just takes a millisecond to process and immediately ignore, slowing the loading time all but imperceptibly...
            Have a good day too...
