    Why Transparency
    5 Posts 2 Posters 439 Views 2 Watching
    • ntxdaveN
      ntxdave
      I am developing a model and it appears that some surfaces are transparent when I really do not want them to be. I need to understand what I am doing wrong.
      As you look at the image, notice that the text at the bottom of the heart as actually on the back side (this is a 3D model) so I should not be able to see that text when viewing from the top. If I look from the other side (bottom) you can see the text that is on the top face.
      I have also been having s little bit of a problem placing text on the top and bottom surfaces.
      Press F1...thank me later
      • TIGT
        If you have accidentally pressed K then back-edges might be 'on'.
        Try pressing K again to toggle them 'off' ...
        ntxdaveN 1 Reply Last reply
        • ntxdaveN
          ntxdave @TIG
          @TIG said in Why Transparency:
          Thanks @tig that solved my problem. What is the K key used for?
          TIGT 1 Reply Last reply
          • TIGT
            TIG Moderator @ntxdave
            @ntxdave
            Showing back-edges can be useful in some modelling and presentations.
            It's default View shortcut is K, but you can also toggled on/off in the Style dialog.
            • ntxdaveN
              ntxdave
              @tig Thank a lot sat. πŸ˜€
