    [Plugin] ms C2C Line 2P
    architecturelandscapedrawing
    5 Posts 2 Posters 688 Views 2 Watching
    • M
      mihais
      ms C2C Line 2P
      (v1.0.1)
      Description: ms C2C Line 2P is a useful extension for quickly drawing centerlines or complex guide lines. Unlike other tools, this one works based on pairs of points:
      • Select the first two points -> The extension creates a guide point at their midpoints;
      • Select the next two points -> The extension creates the second guide point and automatically draws a line between the two midpoints;
      • Continue the selection to generate a continuous path based on midpoints.
      Instalation:
      In SketchUp, go to Extensions > SketchUcation > Extension Store:
      • search for 'ms C2C Line 2P';
      • click 'Install'.
        or
        In SketchUp, go to Extension > Extension Manager;
      • click the “Install Extension” button;
      • select the “ms_c2c_line_2p.rbz” file;
      • restart SketchUp.
      COMPATIBILITY:
      SketchUp 2017 (Make & Pro)
      SketchUp 2022
      SketchUp 2026
      AUTHOR: Gemini AI & 3DxJFD for ms
      LICENSE: GNU GPL
      Download: https://sketchucation.com/pluginstore?pln=ms_C2C_Line_2P
      TIGT 1 Reply Last reply 👍
      • TIGT
        Thanks for this.
        I look forward to it in our PluginStore / ExtensionStore shortly...
        1 Reply Last reply 🙂
        • TIGT
          TIG Moderator @mihais
          @mihais
          I see you're now listed as a developer, so you just need to do the publishing steps...
          • M
            mihais
            Thank you, TIG!
            I've submitted the extension for moderation. Thanks, Rich!
            • TIGT
              It's now available as an RBZ download from our PluginStore or through the SketchUcation > ExtensionStore dialog within SketchUp.
              Well done.
