    [Plugin] FredoSection
    2 Posts 2 Posters 15 Views 2 Watching
    • fredo6F Offline
      fredo6
      This is a PLACEHOLDER for a future plugin, FredoSection
      FredoSection provides several tools dedicated to section planes:
      • Generation of section cut faces with hatching patterns at scale for section planes which are active in scenes.
      • Section box: create a configurable set of section planes (inside box, outside box, custom section line) for a selection of geometry.
      • Door and window schedule: create a permanent companion model with selected views of doors and windows, which can then be mapped at scale in a Layout document. This will be released in a next version however.
      • Pattern Manager: This tool is used to create / modify hatching patterns and assign them to groups and components to decorate their cut faces created by the other tools above. FredoSection comes with a set of built-in patterns, but you can create your own.
      FredoSection is mainly oriented to support a workflow Sketchup + Layout. It only works on Scenes. The hatching patterns are scaled by scene, so that they always appear at the same size when printed on paper. This requires that you assign a paper scale to each scene processed.
      I published 3 videos to give an overview of the main tools:
      • TIGT Online
        Perhaps the best Fredo idea yet !
