    Problems with canceled commands
    7 Posts 3 Posters 945 Views 3 Watching
    • J
      Jspro
      2017 sketchup, when I choose a command such as move, as I zoom out to move an object ( with a three-button programmable mouse from Logitech that I have been using for years)to its desired location the command stops and I have to go back and pick that object and try it again and also it does this with rotate or any other command. I thought it was my computer lack of memory but since then I bought a new computer with 32 memory and it still does this, I have some plugin’s from Fredo and a few others not to say this is what’s causing it. This is new to me for I have been using this program since 2017 and it never did this. Could it be that one of my plugins is causing this?Looking for some suggestions to see if anyone else is having this issue. Thanks John
        Have you pre-picked the object prior to zooming/orbitting?
        Pick Move, pick object then zoom/orbit.
        J 1 Reply Last reply
        • J
          Jspro @Rich O Brien
          @Rich-O-Brien i believe so, I picked the object than I either zoom or orbit, than I lose the command. now not all the time but mostly i have been using sk since 2008 so I'm perplexed. my only thoughts are one of my plugins, but I don't know.
          • BoxB
            I'd be testing with a different mouse.
            J 2 Replies Last reply
            • J
              Jspro @Box
              @Box I will try that, thanks
              • J
                Jspro @Box
                @Box just wanted to let you know that you were right! It was the Logitech mouse software. I really liked that mouse. Now I'll have to go looking for a another programmable mouse. Thanks for your help. John
                • BoxB
                  Hardware wears out and software updates change things. When using old software that isn't being updated you need to look at the things that are changing.
