    Free ai pbr texture generator
    Scheduled Pinned Locked Moved Resources
    4 Posts 2 Posters 1.0k Views 2 Watching
      Hi I am researching free ai PBR texture generators. So I started down the rabbit hole I thought I would ask forums . Has anyone here had much experience with Free ai pbr texture generators they may recommend?
        Are you referring to AI tools that can generate normal, roughness, metallic, ao etc from an input image?
        Or are you referring to a prompt based tool to generate all maps based on your description?
        Try this: https://armory3d.org/lab/
          thanks i would say a tool that would respond to an image perhaps low res, then increase the resolution (if needed) and then create tiled image and normal's diffuse maps Etc,
            Probably ComfyUI workflow would be a path to explore. You can download workflows to try out. ComfyUI itself is a very large download size and balloons further when you add further tensor models etc.
            It's node based too and would require you invest some time learning.
            Armory3D or Substance Sampler[Paid] would be an easier point of entry.
