    [Plugin] A-Visual Tools
    7 Posts 2 Posters 715 Views 2 Watching
      tva84 Newcomers
      Hello everyone.
      I've created a plugin for isolating objects with a logic that I've always wanted. If you select some objects inside a group (deep down in the hierarchy), the plugin hides everything else at the current level. Then, it also hides everything up the hierarchy except for the parent groups. This way, you only get the selected objects, and nothing else is visible in the scene.
      I've also added a button for standard isolation at the current level, as well as a function to do the opposite: show everything deeper in the hierarchy for the selected objects.
      πŸ”½ Download Extension
        tva84 Newcomers
        I can't post anything here because it says I don't have a reputation. I can't even reply in the chat πŸ™‚
          It's an anti-spam measure. You next post should remove that restriction. Just reply to this
          T 1 Reply Last reply Reply Quote 0
            tva84 Newcomers
            I'm not allowed to post here in another way because I don't have enough reputation. Can't even chat back πŸ™‚
              tva84 Newcomers @Rich O Brien
              @Rich-O-Brien I'm not allowed to post here in another way because I don't have enough reputation. Can't even chat back πŸ™‚
                now? you should be free to chat and post
                  tva84 Newcomers
                  Modified the plugin a little. - 1.0.2
                  Changed the menu.
                  Added a new function - Multi-Selection Isolate: isolates objects that are selected in different contexts (located at different levels of the hierarchy). Works slowly when there are a lot of such objects πŸ™‚ But sometimes it can select and isolate something that the usual function cannot.
