    Fredo6 Toposhaper Lisensing Questions
    2 Posts 2 Posters 613 Views 2 Watching
    • C
      chapter_seal
      I'd like to know how to check other licenses
      I can't proceed because there's no pop-up window in the sketch-up program
      A new version of Sketchup Store extension has also been received, but it will not run
        You can use Extensions > Sketchucation > SCFLicense Gloabal Status to check your licenses
        Toposhaper requires Libfredo to be installed to fully function.
        If you run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply I can take a look at your setup.
