Fredo6 Toposhaper Lisensing Questions
I'd like to know how to check other licenses
I can't proceed because there's no pop-up window in the sketch-up program
A new version of Sketchup Store extension has also been received, but it will not run -
You can use Extensions > Sketchucation > SCFLicense Gloabal Status to check your licenses
Toposhaper requires Libfredo to be installed to fully function.
If you run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply I can take a look at your setup.
