    Beveled corners without overlaps
    Scheduled Pinned Locked Moved Solved SketchUp Discussions
    bevelmodelling
    5 Posts 2 Posters 786 Views 2 Watching
      sentur
      Anyway to get big bevelled corners without overlapping geometry?
      I've got this arch wall, that's exectruded inwards ~400mm using PushPull > Thicken. Wall is ~1300mm high.
      Looking to bevel the top corner edges by 300mm rounded bevels or bigger, to have a nice fall off cuve.
      I often have issues like this where I run into the limits of overlapping geo which then dictate the size of the bevel.
      I've been using Fredo6 RoundCorner plugin tools.
      Any solutions?
        That's normal behavior for the method you are using. Easier approach to get the correct result would be to add the corner radius before cutting the large arcs.
        S 1 Reply Last reply Reply Quote 2
          sentur @Dave R
          @Dave-R Thank you.
          I hadn't even considered that as an option as a way to model this geo.
          I'm trying to get the same method to work on more complicated geo, but without much luck. Any ideas on something like this?
            Dave R @sentur
            @sentur How about modeling it flat and then bending it withShape Bender?
            S 1 Reply Last reply Reply Quote 3
              sentur @Dave R
              @Dave-R Ah yeah. That works. Thank you.
              • Rich O BrienR Rich O Brien marked this topic as a question on
