    Vector pushpull throwing up error "argument not valid"
    2 Posts 2 Posters 364 Views 2 Watching
    • B
      bhooknz
      #Vectorpushpull
      Hi, when i try to use the Vector Push Pull tool it throws up an error saying "argument not valid" I have no idea why as I am following a very simple example. It seems to generate the push pull, but when I go to complete it, it barfs.
      below is the .txt.
      Apologies, I am not familiar with code, so hoping someone can help.
      Date: 28-Apr-25 08:14:30 - SU2025.0 - LibFredo6 - v15.3c
      An error occurred in Vector Push Pull
      Error in generation of the geometry
      Not a valid argument type
      jointpushpullgeometry.rbe: 1175 -- *
      jointpushpullgeometry.rbe: 1175 -- block in geometry_hole_cleanup_group
      jointpushpullgeometry.rbe: 1172 -- each
      jointpushpullgeometry.rbe: 1172 -- geometry_hole_cleanup_group
      jointpushpullgeometry.rbe: 500 -- geometry_robot_hole_cleanup
      jointpushpullgeometry.rbe: 238 -- robot_call_action
      jointpushpullgeometry.rbe: 193 -- geometry_robot_exec
      jointpushpullgeometry.rbe: 176 -- geometry_robot
      jointpushpullgeometry.rbe: 81 -- block in geometry_execute
      lib6operation.rbe: 369 -- step_geometry
      lib6operation.rbe: 418 -- start_execution
      jointpushpullgeometry.rbe: 81 -- geometry_execute
      jointpushpulltool.rbe: 1153 -- go_preview_or_geom
      jointpushpulltool.rbe: 876 -- dragging_stop
      jointpushpulltool.rbe: 1579 -- onLButtonDown
        many factors could be the cause. From outdated extensions to troublesome geometry.
        If you shared the file and versions of JPP and Libfredo you are running it would be helpful.
