    Creating lots of intersection lines
    3 Posts 2 Posters 175 Views 2 Watching
      Joel3dm Newcomers
      I'm working on a model with many pipes going thru many faces. I want to add intersection lines. I can use the Intersect With command no problem. But there are many faces and I wonder if there's a plugin that will create intersection lines globally.
      Joel
        Rich O Brien Moderator @Joel3dm
        @Joel3dm said in Creating lots of intersection lines:
        Just group pipes and faces and use the Intersect command on your selected groups.
        It will create intersection geometry outside the selected groups that you can then merge with whatever you need to.
          Joel3dm Newcomers
          Thanks!
