    Fredo 6 Animator Rotation Issue
    2 Posts 2 Posters 121 Views 2 Watching
    • G Offline
      Gustavo SG Newcomers
      Hey guys,
      I have started having an issue with the rotation function of Fredo 6 Animator that started after the newest update.
      The issue is that when rotating a group, said group will sometimes break apart and rotate across seemingly different pivot points or the whole thing will just rotate progressively further away from the pivot point I set for it.
      Here is a video of said problem of an object rotating further away from the pivot point I set for it (Broken) Film 1.mp4. In the video I have a frame that is supposed to tilt 90% upward on the table, I set the pivot point accordingly but when I play the animation it ends up rotating further away and I cant find a solution to this.
      Any recommendations on what to do to avoid this issue or to fix it is appreciated.
        Its most likely you are rotating about another objects origin point.
        Hovering an element in the timeline is a good clue
