    SU imported texture resolution
    3 Posts 2 Posters 479 Views 2 Watching
    • L
      Hi I am importing textures at hi res into SU. When I do a render the textures they look low res Does SU support hi res textures?
        You can set SketchUp to use max texture size...
        I've never found further info on its usage other than its off by default to keep SketchUp performant.
        But if your render app is showing lower resolution its likely related to the app rather than SketchUp.
        • L
          Thanks Rich
