    Sketchucation store plugin toolbars.
    6 Posts 2 Posters 501 Views 2 Watching
      I installed Sketchup 2024 on this pc and added the styore plugin in the usual manner.
      The plugin bundle goes through the motions of installing which seems to go well but, no toolbars. Store is v4.4.1.
      Works fine in Sketchup 2022.
      TIGT 1 Reply Last reply Reply Quote 0
        TIG Moderator @Mike Amos
        @Mike-Amos
        Are things shown as 'installed' in the native Extensions Manager dialog ?
        Is the SketchUcation Toolbar listed as an available toolbar ?
        Have you tried activating it ?
        Is SketchUcation listed under the Extensions menu - you can activate it from there too ?
        or... are you saying something else ?
        Are you saying that the Plugins [Fredo's?] aren't listed in the Tools menu items ?
        Do you have the latest version of LibFredo6 installed ?
        Have you restarted to sync everything after the installations ?
        Have you downloaded the appropriate licenses
        Have you validated those licenses for each extension ?
        More info please...
          Mike Amos @TIG
          @TIG
          I have gone through the Sketchucation extension store 'install bundle' route.
          The only non Trimble extension I can see is the extension store plugin toolbar. Nothing else visible and not seen in the Trimble extension managemer either.
          When I install the bundle there is a report that all nplugins have been successfully installed.
          Yes, I have restarted post install.
            Mike Amos @Mike Amos
            I know it is not the favoured method but, I copy and pasted the Sketchup 2022 plugins folder into Sketchup 2024 after renaming the current folder as Plugins old.
            Toolbars present and correct.
            The initial instal via the extension store apparently installed the bundle but nothing was showing in the pl;ugins folder but the default plugins and the extension store.
            Keeping an eye on changes.
              @Mike-Amos
              Did you install SketchUp 2024 in the approved way ?
              You can repair it either way...
              Close v2024.
              Find the v2024 installer's exe file [usually in your Downloads folder]
              Select its icon, right-click > context-menu > Run as administrator...
              When prompted choose 'Repair'.
              When it completes restart SketchUp.
              Any better ?
                Mike Amos @TIG
                @TIG
                I did the usual repair, tried initialy numerous times to install the 'bundle', each time it was reported that the install went well TT library had to be completed seperately but this was NOT an issue.
                The copy and paste method worked.
                Odd, I know.
