    Fredo Push Pull tool on SU17 Make
    8 Posts 2 Posters 290 Views 2 Watching
    • R
      Rolo95 Newcomers
      Guys,
      i am drawing a speaker,
      and need to extrude the curved shapes of the metal spider in the back
      so i found that fredo push pull tools can do it
      does the fredo tools work under SU17 Make ?
      if so how i can get a license for it
      Rolo.
        Rich O Brien Moderator @Rolo95
        @Rolo95 it has a free trial so just install SketchUcation Tools and use that to install extensions
        R 1 Reply Last reply
        • R
          Rolo95 Newcomers @Rich O Brien
          @Rich-O-Brien
          I did, but and i click install and it says installed
          but nothing happens, i did not see it in the list of tools , i can do it manually
          but i do not know where the .rbz file is downloaded
            @Rolo95 Fredo's extensions require LibFredo to fully function.
            He has free legacy versions if you search for them
            SketchUp Plugins | PluginStore | SketchUcation
            SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
            (sketchucation.com)
            I don't know what works in 2017 if I'm honest. Its 7 versions ago so you'll need to do some groundwork on your end.
            • R
              @Rich-O-Brien I did installed LibFredo , and i get that the license expired in 2021
              is the free legacy plugs still alive ?
              and how much is to get the push pull license
                @Rolo95
                (sketchucation.com)
                  Those are pre-2017 if you have that installed then they are free
                  Anything above requires a license if trial period is over...
                  SketchUcation | List of Plugin Licences
                  (sketchucation.com)
                  • R
                    @Rich-O-Brien
                    Thanks !
