    Part not printed as drawn
    Scheduled Pinned Locked Moved Solved SketchUp for 3D Printing
    5 Posts 2 Posters 986 Views 2 Watching
    • A
      Alohaa
      Hello,
      I have drawn and printed an adapter to attach a limit switch to my drawing machine.
      A first part (the left one in the SU file) was printed as drawn, a second, slightly modified one, was not. This should be 4mm thick at the top but only has 2; what is missing is 2mm and the countersinks around the slotted holes.
      It should be noted that I did not touch the upper part in comparison to the first one, except that I rotated it by 90°.
      What could be the reason for this?
      Kind regards
      Alohaa
      Adapter.skp
      Dave RD 1 Reply Last reply
        Dave R @Alohaa
        @Alohaa said in Part not printed as drawn:
        I don't quite understand what it means that it's not solid.
        In order for a group or component to be considered a solid, or manifold, every edge must be shared by exactly two faces, no fewer and no more. So no stray edges, no holes in surfaces or missing faces and no internal faces. To be properly 3D printed all faces must be correctly oriented, too. That means the white front faces must be facing the air and the blue back faces are toward the print media.
        Nested groups and components will never be considered solids because they contain more than just edges and faces.
        What do you mean by that?
        The edges and faces in the space between the object on the bottom and the one on the top are just loose geometry. Compare your model to the one I shared.
        What did you do exactly?
        I exploded the groups inside the top level object, removed a bunch of stray geometry and other cleanup. the Solid Inspector2 extension helps to identify problems. It might fix some of it.
        The fact that I drew these parts in mm didn't cause any problems, or am I seeing it wrong?
        It didn't in this case but you can create smoother curves and other small details if you need it.
        Incidentally, I recently printed a part I had drawn in metres without scaling it down because I had forgotten it was in metres, and it printed correctly, which I was amazed at and still don't understand!
        The .stl file you exported has no units. It's only numbers for the sizes. So you can export with the model units as meters and import into the slicer as millimeters.
        A 1 Reply Last reply
          Dave R @Alohaa
          @Alohaa neither one of the objects is a solid in SketchUp. The L-shaped one contains two non-solid objects and loose geometry between them. There's also a lot of garbage geometry and there were some reversed faces, as well.
          I've cleaned them up so they are both solids.
          adapter fixed.skp
          I'm curious. Why are you modeling these so small? We already gave you the advice to model in meters, export in meters, and import the .stl into the slicer in millimeters.
          • A
            Alohaa @Dave R
            Thank you very much for all the work you have done with my faulty drawings!
            @Dave-R said in Part not printed as drawn:
            That would mean that I am not proceeding correctly by drawing a surface and extruding it!
            I proceeded in such a way that I put both parts on top of each other, and on. 2 sides by creating inclined planes by drawing the individual lines to connect the parts more strongly.
            What is garbage geometry?
            I looked closely for superfluous geometry by displaying the part in the X-ray mode and found nothing superfluous.
            I had forgotten it again, but this is only necessary in various (although I don't know in which!) situations, or not? The fact that I drew these parts in mm didn't cause any problems, or am I seeing it wrong?
              Dave R @Alohaa
              • A
                Alohaa @Dave R
                @Dave-R Thank you!
                • Rich O BrienR Rich O Brien marked this topic as a question on
