    SU freezes
    3 Posts 2 Posters 359 Views 2 Watching
    • L
      Leggy
      ’ve been having problems on 2 different Mac’s, but the same problem
      I click on a tool, line ,tape measure, erase and it wont work
      I’ve found by using save the program works again, and then it happens all over again
      Anyone else have this problem?
        Rich O Brien Moderator @Leggy
        @Leggy Never experienced it. Best thing to do is rule out extensions by renaming your plugins folder to prevent it loading to see if running in vanilla remedies it.
        If yes, then you need to track down what is causing the issue.
        If no, it maybe be hardware related so poke about the settings to see if lowering values sort things out.
        • L
          Leggy
          It’s now doing the same thing on my new m2 Mac mini, have to save as , then able to carry on
          So frustrating
