    Camera management
    Scheduled Pinned Locked Moved Resources
    3 Posts 2 Posters 546 Views 2 Watching
      I am looking for a camera tool that enables me to set location, alignment, height AND view size/
      I want to be able to soze the viewed area specifically and 'crop' it to the relevent area of the scene basically, as is, I cannot do this.
      Quite aware I can do something like this in post pro but there are usually 'areas' missing in this instance and constantly panning the camera view all over the shop to try and fix it is fruitless.
      I know there are various camera 'apps' out there, I just need to know which does the trick please.
        Fredo Portrait allows you to control orientation of a camera but not world position.
        SketchUp's native Position Camera tool allows you to place a camera at a location then set it's height. If you then switch to Zoom tool and hold SHIFT you set the FOV.
        I use a mix of those 3 to create cameras
          Mike Amos @Rich O Brien
          @Rich-O-Brien
          Thanks Rich, playing around now.
