    Sketchucation Tools on SU 2020
    2 Posts 2 Posters 157 Views 2 Watching
    • ntxdaveN
      ntxdave
      Will the latest version of SketchUcation Tools work on SU 2020? I finally got SU 2020 working on my new laptop and now need to the my extensions working. If I install SketchUcation Tools I would then be able to use the Bundles to install my extensions on the new machine.
      So, again, what version of SktechUcation Tools do I need to install with SU 2020?
      Press F1...thank me later
      TIGT 1 Reply Last reply
      • TIGT
        TIG Moderator @ntxdave
        @ntxdave
        The current version of SketchUcation Tools works on versions >= v2017
        If you have bundles relating to other versions [newer or older], then you should be able to use them in v2020...
