    Rotate Plan View - Updated for 2024
    6 Posts 3 Posters 494 Views 3 Watching
    • S
      Sl-m
      Re: [Plugin] (TIG) Rotate Plan View v1.1 20110316
      Hi TIG,
      This plugin of yours was a gem!
      Unfortunately it doesn't work with sketchup 2024.... Any update soon?
      Thank you.
      TIGT Z 2 Replies Last reply
      • TIGT
        TIG Moderator @Sl-m
        @Sl-m
        First report of an issue - I'll investigate...
        TIGT 1 Reply Last reply
        • Z
          zfjoy520 Newcomers @Sl-m
          @Sl-m
          It's too simple, edit the plugin file with notepad like this:
          open a terminal with command "cmd", and copy the code, mouse right click or Ctrl + V to paste the code into the terminal.
          notepad.exe "%HOMEPATH%\AppData\Roaming\SketchUp\SketchUp 2024\SketchUp\Plugins\Rotateplanview.rb"
          find and remove the 's' from Line 76,
          change "if File.exists?" to "if File.exist?" and save it.
          reboot your SU 2024, it's ok now.
          • TIGT
            TIG Moderator @TIG
            @TIG
            It was indeed File.exist? v File.exists? which had worked side-by-side for decades, but in v2024's Ruby only the former works !
            This has affected lots of older or lesser used plugins...
            v2.0 is now available in the PluginStore.
            The exist? issue was easily done but I also fixed somethings that were archaic in the 13 year old code - like not having its own proper namespace etc.
            Its RBZ is also now signed etc.
            Get it here ...
            https://sketchucation.com/pluginstore?pln=Rotateplanview
            Z 1 Reply Last reply
            • Z
              zfjoy520 Newcomers @TIG
              @TIG
              Yes, in SU 2024, not only File.exists? is removed, Fixnum in SU 2024 raise errors too.
              see Ruby 3.2 full release notes here:
              https://github.com/ruby/ruby/blob/v3_2_2/NEWS.md
              We fixed in our plugins like this:
              # Fix undefined method `exists?' error for Dir:Class, File:Class
              # see: https://github.com/ruby/ruby/blob/v3_2_2/NEWS.md
              # Removed methods:
              # Dir.exists? [Feature #17391]
              # File.exists? [Feature #17391]
              Dir.respond_to?(:exists?) || Dir.singleton_class.alias_method(:exists?, :exist?)
              File.respond_to?(:exists?) || File.singleton_class.alias_method(:exists?, :exist?)
              defined?(::Fixnum) || Kernel.const_set(:Fixnum, Integer)
              • TIGT
                TIG Moderator @zfjoy520
                @zfjoy520
                Also some URI stuff is FUBAR in v2024 too...
