    Purge is crashing SU2024
    4 Posts 2 Posters 716 Views 2 Watching
    • grizzlerG Offline
      grizzler
      Initially I assumed there was an issue with the model I was working on, but it's every model I'm working on: Model Info > Statistics > Purge Unused = crash.
        I don't see this.
        I assume you are using Windows ?
        When you installed SketchUp did you do it the proper way ?
        You can 'Repair' the installation without losing any of your customization.
        Do this...
        Close SketchUp.
        Find the SketchUp installer's exe file - usually in your Downloads folder [download another copy if you haven't kept it]
        Select the installer's exe file's icon and right-click > context-menu > 'Run as administrator'
        When prompted choose 'Repair'.
        When it completes restart your computer and try SketchUp again...
        Any improvement ?
        Also look at your Preferences and try different Graphics Card / Engine settings...
        grizzlerG 1 Reply Last reply Reply Quote 0
        • grizzlerG Offline
          grizzler @TIG
          @TIG It's definitely installed correctly following me doing exactly as you described for 2023 version issues. It must either be the primary template I use for most projects (was fine in 2023), or that Sketchucation 4.2.9 is an unsupported extension and causing some kind of problem - that seems a bit of a stretch though.
          TIGT 1 Reply Last reply Reply Quote 0
            TIG Moderator @grizzler
            @grizzler
            You should go to the PluginStore and update to the SketchUcation toolset v4.4.0 which has been specially reworked for v2024 compatibility. If deals with the SCF licensing for many extensions.
            If you use any of Fredo's extensions, he has also updated them all for v2024 use and don't forget his latest LibFredo too...
            After installing these restart SketchUp to sync everything...
