    Another House in D5
    12 Posts 6 Posters 531 Views 6 Watching
    • Gus RG Offline
      Gus R
      Originally modeled for a NPR render in 2011 for Chalet Colorado. I reworked the model and rendered it here in D5 Render.
      This was the original render generated in SU with some Photoshop work.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      • ntxdaveN Offline
        ntxdave
        πŸ‘ πŸ‘ πŸ‘
        Press F1...thank me later
        • marked001M Offline
          marked001
          Very nice!
          http://www.revision21vis.com
          instagram: revi21on
          • Bryan KB Offline
            Top notch! πŸ‘
              Very nicely done, great stuff. πŸ‘ πŸ‘
              • Gus RG Offline
                Gus R
                Thanks guys. I modeled the entire house including the windows and doors with the help of a plugin. That was tedious. This was before Flex Tools. D5 Render has those nice procedural vines. Only problem with that is they change every time you open up the file.
                  marked001
                  I'm having a tough time figuring out how to use those vines. Lumion is definitely superior when it comes to that. That really stinks that they change every time.
                  instagram: revi21on
                  • Gus RG Offline
                    Gus R
                    Seems to work when you first apply the vine on the side of the face you want the vine to go. You get that blue cast and the vine logo and then rotate it from there. You have to move it around a touch and then it goes on the right face. I applied it first on a wall just now and you then have to rotate it 90 degrees and pull it back for the blue cast to show up. If that all makes sense I don't know.
                    • Gus RG Offline
                      Gus R
                      Looks like it's more random hit and miss. I think it's still in beta.
                      • majidM Offline
                        majid @Gus R
                        Looks nice,
                        I am interested to know what parts are done inside Sketchuo, Are IVYs part of the Sketchup model?
                        • Gus RG Offline
                          Gus R @majid
                          @majid said in Another House in D5:
                          Looks nice,
                          Thanks Majid. This is the extent of all the Sketchup work. The rest is D5 Render assets. The vines are also from D5 with their recent addition of vine procedurals. The arched brick is done first with Curviloft and I settled on using Quadface Tools for mapping.
                          majidM 1 Reply Last reply Reply Quote 1
                          • majidM Offline
                            majid @Gus R
                            @Gus-R Thank you for sharing, this is too informative
