    How to export animation background transparently
    5 Posts 2 Posters 574 Views 2 Watching
      cc0055 Newcomers
      Hi, I'm a foreigner. It might sound weird because I'm using a translator.
      Can I make the background transparent when saving animations as PNG?
      I turned off the sky and set the background to perfect 255, 255, 255.
      If I export it in 2D, the background is transparent without any problems, but if I use animation export, it's just a white background.
      I can't use 2D export because I need a camera walk that occurs when I switch scenes.
      I know it's possible in the MAC version, but I'm in the Windows version.
      Green screens (chromaquis) cannot be used to perfectly export objects with slight transparency, such as windows and glass cups.
      Alpha Channel was also difficult to implement slightly transparent objects. But if you can implement transparent objects, Alpha Channel is also good.
      In my country, I couldn't get any information no matter how much I searched.
      This was the only site that asked the same question as me while searching for 3 days and nights.
      But it was all a post a few years ago and I didn't get any meaningful information.
      Now that it's been a long time, maybe someone could succeed?
      It doesn't matter if it's a plug-in or a ruby console. Someone help me, please.
        Have you tried Animator?
        It can export image sequence as png
        https://i.imgur.com/lZxayO7.png
          cc0055 Newcomers
          Oh, my God! Oh, my God!
          I knew this plug-in, but I didn't know how to use it because I wasn't good at English.
          But when I saw your writing, I felt there was a hint, and after digging in, I was able to get what I wanted. If it wasn't for you, I wouldn't have used this plug-in forever.
          Thank you so much!! Really!! 😒 😒
            No probs just use the Insert Camera function and target your scenes
            https://i.imgur.com/vdWrkWi.png
              cc0055 Newcomers
              Thank you for your kindness! I solved the problem that was bothering me! You are the best.<3<3 πŸ‘ πŸ‘ πŸ‘
