    Importing text
    5 Posts 4 Posters 618 Views 4 Watching
    • pmolsonP Offline
      pmolson
      I have always just accepted the fact that Text does not import when I import an acad file (.dwg)
      into sketchup.
      I never thought to ask you all if there is a way to get text to come along with the .dwg file .
      Is there?
      Paul
      • G Offline
        GFXS
        Didn't TIG create an extension to import DXF text? Thought I read it here somewhere...
        • G Offline
          Glenn at home
          That's usually the 1st thing I filter out of a dwg before going into SU. Are you using them for a particular reason or just reference?
          • TIGT Online
            There's an extension of mine in the PluginStore which imports DXF text...
            It's not entirely idiot-proof, but for most text it'll work, you mustn't change the text-dxf's origin compared to the main geometry's dxf/dwg import - otherwise things won't align...
            Read the usage notes...
            https://sketchucation.com/pluginstore?pln=importDXFtext
            • pmolsonP Offline
              pmolson
              TIS FOR REFERENCE.
              I can look at the cad file separately on one of my screens but I have always wished I could have the text right in the imported cad file on a separate layer so I can switch it off & on rather than turning my head...yeah, I know...lazy.
              Thanks TIG,
              I figured you probably addressed this 100 or so years ago.
              p
