    Part of a line?
    4 Posts 4 Posters 356 Views 4 Watching
    • D
      djh
      The eraser tool deletes the entire line. Can one erase part of a line?
      • L
        Draw a line or a number of lines intersecting the line you want to edit the line you which to edit wile be split by the intersect, Then delete what you wish to delete
          A curve could be a line with multiple segments so if you try to delete a segment it will delete the whole curve.
          Use the entity info panel to deduce what property it has.
          • Jean LemireJ
            Jean Lemire
            For a curve you have two choices :
            1 - Use the same method as what was shown for a straight edge.
            2 - Explode the curve then delete unwanted segments. Of course parts of segments can be deleted if method 1 is used.
