    Bug report submit
    2 Posts 2 Posters 173 Views 2 Watching
    • A
      aarndt71 Newcomers
      Not sure where to post this bug report:
      Date: 29-Apr-23 19:27:55
      An error occurred in FredoCorner
      An error occured in the Ruby code
      undefined method `ptcross=' for nil:NilClass
      fredocorneralgo.rbe: 2320 -- brane_free_chemin
      fredocorneralgo.rbe: 2057 -- block in catena_process_branes_protected
      fredocorneralgo.rbe: 2047 -- each
      fredocorneralgo.rbe: 2047 -- catena_process_branes_protected
      fredocorneralgo.rbe: 2009 -- block in catena_process_branes
      fredocorneralgo.rbe: 2008 -- catch
      fredocorneralgo.rbe: 2008 -- catena_process_branes
      fredocorneralgo.rbe: 965 -- block in solid_construct_branes
      fredocorneralgo.rbe: 964 -- each
      fredocorneralgo.rbe: 964 -- solid_construct_branes
      fredocorneralgo.rbe: 919 -- block in solid_reconstruction
      fredocorneralgo.rbe: 918 -- each
      fredocorneralgo.rbe: 918 -- solid_reconstruction
      fredocorneralgo.rbe: 883 -- solid_add_remove_edges
      fredocornertool.rbe: 1840 -- selection_change
      fredocornertool.rbe: 1828 -- selection_add_remove_edges
      fredocornertool.rbe: 1851 -- selection_set
      fredocornertool.rbe: 1533 -- block in preselection_instantiate
      fredocornertool.rbe: 1530 -- each
      fredocornertool.rbe: 1530 -- preselection_instantiate
      fredocornertool.rbe: 1525 -- preselection_analyze
      fredocornertool.rbe: 761 -- true_activate
      fredocornertool.rbe: 746 -- block in activate
      lib6plugin.rbe: 1812 -- block in tem_context
      lib6plugin.rbe: 1896 -- tem_context
      fredocornertool.rbe: 746 -- activate
      fredocornertool.rbe: 194 -- select_tool
      fredocornertool.rbe: 194 -- launch
      fredocornertool.rbe: 176 -- action__mapping
      data6.rb: 65 -- call
      data6.rb: 65 -- launch_action
      lib6plugin.rbe: 240 -- launch_action
      bootstrap_fredocorner.rbe: 103 -- launch_action
      bootstrap_fredocorner.rbe: 118 -- block in startup
      lib6plugin.rbe: 1469 -- command_invoke
      lib6plugin.rbe: 1449 -- block (2 levels) in build_config_commands
      lib6traductor.rbe: 1385 -- block in add_command
        Considering its related to FredoCorner I'd suggest here...
        https://sketchucation.com/forums/viewtopic.php?f=323&t=70149&sid=f16be25bfb587881f1f6ac71cc3bcc84#p639545
