    Heavy STL
    12 Posts 3 Posters 623 Views 3 Watching
    • L
      Leggy
      Hi i downloaded a STL file of a intricate vase, must have 500k faces, i want to cut it in half horizontally and just print the lower part
      I tried putting a plane through it and delete the top half,…well after about a hour of watching the spinning ball, i shut the computer down
      Any one got a work around this?
      Thanks Dean
      • BoxB
        There are a variety of options, waiting being one of them, but without seeing the stl it would be guessing.
        • L
          Leggy
          I’m not at work until Saturday will post then
          • L
            Leggy
            Hi I’m having a problem uploading the stl file
            First attempt said upload failed, second one I watched for 15 minutes as it slowly loaded then I left the shop
            The file is 315mb which I think maybe is too big to upload
            What do you think?
            • BoxB
              That's about 312mb over the forum limit.
              That is a ridiculously large file for one vase.
              You could upload it to dropbox or similar and post a link to it here, someone may look at it. It is too big for me to download on my limited internet.
              Perhaps a screenshot to begin with would give us some idea of what you are dealing with.
              • L
                Leggy
                How did you do it?
                Another problem ,in sketch up I’ve put a hole in the bottom of the gnome, but in Cura it’s filled in
                • L
                  Leggy
                  Screenshot is too big aswell
                  If you go on thingiverse and look for Christmas gnome, you can see it
                    https://www.thingiverse.com/search?q=Christmas+gnome&page=1&type=things&sort=relevant
                    There's many gnomes to pick from...
                    I had a look at the first .stl and its mesh is not manifold. So that needs fixing. The bottom of the hat, at the back, stands out.
                    But it's definitely doable...
                    https://i.imgur.com/rq2kP3m.png
                    • L
                      Leggy
                      How do you reduce a photo so it can be posted?
                        @leggy said:
                        How did you do it?
                        Boolean subtract using solid tools
                        Can't help I'm afraid. Cura is a fungal nail remedy in my part of the world.
                        I use imgur to host images and then use the bbcode with the url for the image to embed it.
                        [img]https://i.imgur.com/rq2kP3m.png[/img]
                        • L
                          Leggy
                          Could you explain the solid tools a bit more
                            They are part of SketchUp. There's already extensive help docs under the help menu on how to use them.
                            It's a boolean subtract method. So select the cutter then the target and click Subtract. Go make a coffee, read the news and watch the clouds for a bit. When you come back it'll be done.
