    Problem flowify
    15 Posts 2 Posters 974 Views 2 Watching
      stefan81222 Newcomers
      hello everyone i'm a beginner in 3d modeling i'm trying to use flowify to create a cushion sofa model...but i don't understand why i keep making mistakes with the plugin...can anyone help me?
      sofa.skp
        Can you save your model in SU 2017 for a more large audience ?
        Sur I can use the very cool free Pconplanner for that but... πŸ˜„
          No problem... πŸ˜„
            I believe that you must have your surface made with these 4 curves! πŸ˜‰
            Tig has a cool one for that! πŸ˜‰ Extrude Tool and take the first one πŸ˜„
            (pick Profil 1, rail 1, rail 2, profil 2 )
              As your object to project is very heavy that can take several minutes to do! πŸ€“
              Object to project must be an only one object and not an object of objects! πŸ€“
              [attachment=0:2lby85ww]<!-- ia0 -->flowify.jpg<!-- ia0 -->[/attachment:2lby85ww]
                so i downloaded and installed extrude tools..i just don't understand very well what i have to do to my solid with that tools...should i select the figure? make it new with that tools? I don't understand...
                  It's for make your target surface!
                  You must draw first 4 separated curves (but connected by their extremities)
                  Call the first TIG Extrude Tool
                  Click the left Profile 1 (the red one above)
                  Click one Rail 1 ( up green curve) 2
                  Click second Rail 2 ( bottom green curve )
                  Click the right Profile 2 ( red curve again)
                  Like this you can create any surface defined (here 4 ) by 3 or 4 curves (Coons Surfaces)
                  (in case of 3 curves click twice on the Rail)
                  You can now apply your Flowify with confidence! β˜€
                    I'm sorry...but I can't...I try and try...can you tell me where am I going wrong?I create the curve..but all I get with the extrude edges by rail plugin is that...help
                    test.skp
                      Your 4 curves are maybe not welded themselve?
                      And your drawing is curious ! It's a canoe ?
                      I have just keept your 2 Profiles and draw any 2 other rails...
                        not a canoe heheh...so if I make curves at random the plugin works...the shapes come to me...but when I try to do it with the empty profile I drew of the sofa...it can't do it... I don't understand where I went wrong in creating that specific profile...
                        test sofa.skp
                          it's not version 2017! πŸ˜‰
                            sorry...
                            test sofa 2.skp
                              Yes it's that!
                              You must redraw your curves for have 4 curves welded!
                              Use the Fredo Bezier plugin for have automatically 4 curves welded!
                              https://sketchucation.com/pluginstore?pln=BezierSpline
                              In another case you can use the recurve plugin for weld curves selected!
                              https://sketchucation.com/pluginstore?pln=recurve
                                but
                                Diggsey: Recurve v1.5
                                it doesn't seem to work on sketchup pro 2022...it is installed but I can't find it in the control panel...
                                  It's a contextual menu on the right Click when something is selected! πŸ˜‰
