    Central pool.
    16 Posts 3 Posters 724 Views 3 Watching
    • Mike AmosM Online
      A compound type residence interior has a pool for multi purpose use.
      Only a little way in.
      • Bryan KB Offline
        It took me a while but I think I see what it is now. It's a raised platform, over the water with a "sling/suspension" bridge to it?
        Cool concept.
        • Mike AmosM Online
          Yes maye, there is now a 'suspension tower/sunshade over the doughnut which will support the platform/bridge.
          • Bryan KB Offline
            Oh that's very nice! πŸ‘
            Very cool concept!
            • Mike AmosM Online
              Ta mate, not quite your space ships but getting there slowly.
              • Mike AmosM Online
                I added a HDRI and Filmic post pro in Twilight Pro V2.
                • Bryan KB Offline
                  Whoa! Nice! πŸ‘
                  • Mike AmosM Online
                    Thanks mate.
                    • Mike AmosM Online
                      Early doors night render.
                      • Bryan KB Offline
                        Looking good! πŸ‘
                        • ntxdaveN Offline
                          ntxdave
                          Like this latest view the best....looks more realistic to me. πŸ‘
                          Press F1...thank me later
                          • Mike AmosM Online
                            Ta folks. πŸ‘
                            • Mike AmosM Online
                              Picking this up again as I had a thought on more realisticsettings for the birds. I reduced the hdri to 10 percent to accentuate the artifical lights. This was a suggestion from Fletch which I appreciate.
                              • Bryan KB Offline
                                Hmmm. Contrast looks a little to high.
                                I'm not familiar with Twin Motion, but does it have a separate "sun" setting? Raylectron and D5 both have separate sun settings that have to be turned off when using an HDRI. Although sometimes I will still use the sun, just set a lot lower, as fill lighting.
                                I wonder if that may be the source of the high contrast?
                                • Mike AmosM Online
                                  TBH, I have little clue about TM, still using Twilight render.
                                  Still playing with the settings and for example, saved the image as HDR and EXR (In Twilight render) to see what was what. Much more depth of lighting info in these file types but frankly I am clueless as to how to manipulate the result.
                                  It would certainly add a lot of time to the render process as both are pretty grainy.
                                  • Bryan KB Offline
                                    Twilight.
                                    Oops. My bad.
                                    Sigh, this is why I'm taking a break. Between the weather and seasonal allergies, I am not firing on all cylinders.
