    Sky rendering in Sketchup with Twilight Render HELP !
    4 Posts 4 Posters 225 Views 4 Watching
      MarieEve Martel
      I'm new here so I don't even know if I'm posting in the right place, I apologize in advance if so. I'm having trouble with two things;
      1- Finding good spherical skies (for free)
      2- When I try to render with what skies I found, I don't have all the fine high lights rendered in the main rendering window, but I do in the "Exploration Render" window. Can anyone take a good guess at why that problem occurs ? This is with a "Spherical sky" and a jpeg image as background image. I did try different levels of rendering (from low+ up to high+) in the render presets, and still no "fine high lights details", but the Exploration Render window gives a very low definition rendering anyway, so that shouldn't be the problem logically. I also tried with physical sky, and it's the same problem.
      If anyone has any advice, I would appreciate it very much, and again, sorry if this isn't the correct place to address this specific topic, but my head is dizzy with all the tutorials, researching and mistrials.
      PS: I did try the Twilight Render forum, and have gotten no answer, so here I am.
      PPS: I dragged and dropped images to illustrate the problem, I hope that worked.
      Low+:
      [img]/Users/marie-evemartel/Documents/ARTS%20VISUELS/OEUVRES/Expériences%20SKETCHUP/TWILIGHT%20RENDER/Problèmes/hautes%20lumières%20invisibles/Low+%20res.jpeg[/img]
      High+:
      [/img]/Users/marie-evemartel/Documents/ARTS VISUELS/OEUVRES/Expériences SKETCHUP/TWILIGHT RENDER/Problèmes/hautes lumières invisibles/High res.jpeg[/img]
      • ntxdaveN Offline
        ntxdave
        I would suggest you post your problem on the Twilight Render forum. I think I have seen something somewhat similar on their forum. They also two VERY good support people (Fletch and Chris).
        Press F1...thank me later
        • tuna1957T Offline
          tuna1957
          I believe you ( MarieEve ) have gotten responses from Fletch and Chis over on the Twilight forum. Are you still having problems ? Hard to give advice without images or a .skip file to look at …
          • Gus RG Offline
            Gus R
            You can find a bunch of free HDRI skies here at ambientCG.
            www.instagram.com/gusrobatto/
            www.facebook.com/gusrobatto
