    Photomerge of a previously exported image?
    6 Posts 3 Posters 417 Views 4 Watching
    • N Offline
      nasmrtcz
      Dear modelers,
      I would like to ask you about a mystery that I have never been able to solve.
      Is there any way to export an image, modify it (by PS/hand) and import it back to the saved camera so that I can project it onto the model?
      If I use photomerge, I have to re-set the perspective, which is tedious.
      Watermark won't do the texture.
      Both SketchUV and FredoThruPaint can be used, but it's terribly complicated for each export-import.
      I have needed this exact thing many times, never found an answer here or elsewhere.
      Mira
        I use the Combine Textures hack to get planar faces with various materials to bake to one image and export that.
        I know of no way to do what you need in SU though except for the labour intensive method you mention.
        Have you tried importing SKP into Blender and use that the Project UVs from view?
          What version of SketchUp are you using? Please complete your profile. Might be easier to edit the textures in Photoshop rather than doing what you describe.
          • N Offline
            nasmrtcz
            Hi, I'm using version 22.
            It's always been a very big pity that I made drafts, printed them, then painted or redrew anything (or my boss did) and needed to get it back and preferably via the "Project texture" tool.
            Worst of all, it's needed more and more in the age of image generators. I export an image, redraw it in the generator, need to get it back as a texture and there is no way to do it.
              Please update your profile.
              It would help if you would share a SketchUp model and an image of what you are trying to accomplish. Why not just make textures to import into SketchUp and save yourself the trouble?
              • N Offline
                nasmrtcz
                Hi everyone,
                it took several years, but I figured it out!
                It's one of the most hidden features in SketchUp.
                If you want to export an image, draw on it with crayons or edit it in Photoshop ...or AI and then map it back, you must activate a scene with a saved camera and then click to create a new photomerge -> the vanishing points will be set according to the last scene. Then you can select the edited visualization and project it precisely onto the model as a texture. Amazing, right?
                It never works otherwise if a saved camera isn't activated first.
                The second hidden trick is equally clever. Did you think that exporting 2D DWG with edges colored by layers only works through layout? Miracle, it works in the sketchup too. Just set edges color by material and have Color by Tag activated in layers/tags, then create a Scene with saved Styles (+update the scene to save the style), keep the scene active and export 2D DWG. Aaand is colored. If the style isn't saved in the active scene, it won't work.
                Ns.
