    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Alphabet to sketch(up)
    204 Posts 7 Posters 13.7k Views 7 Watching
    • ntxdaveN Offline
      ntxdave
      Well, here is my latest work. The letter Q was the "inspiration" for this sketch and render.
      The windows did not turn out exactly as I had hoped. The reflection seem not to appear in all of them.
      Press F1...thank me later
      • majidM Offline
        majid
        Nice result mate!!
        Do you mind sharing more renders from different angels too?
        • ntxdaveN Offline
          ntxdave
          @majid said:
          Nice result mate!!
          Do you mind sharing more renders from different angles too?
          Thanks.
          At some point, I will. However, some parts were only done for this view so I will have to finish the model. โ˜€
          • ntxdaveN Offline
            ntxdave
            Another practice sketch. Several things wrong that I can to do better before taking building into SketchUp but again learning more about sketching (using Sketchbook on my iPad for my sketches.
            โ€œPracticeโ€ for letter S
            Hope you can see which letter of the alphabet is my inspiration. ๐Ÿ˜„
            • majidM Offline
              majid
              Another nice start.
              Needless to declare that there is no obligation to stick to the initial form.
              I also have shared samples. In fact as it is believed in "lateral thinking" those sketches are to make us think out of box.
              • ntxdaveN Offline
                ntxdave
                @majid said:
                Nice result mate!!
                I did do some new/multiple renders which I posted on this Twilight Render forum thread Alphabet Inspired Sketches.
                I am not happy with the results though. I tried to use the trial version of the Skatter plugin but still have a lot of things to learn so I can get tepee landscape and background better. When that happens I will post some new renders.
                • majidM Offline
                  majid
                  I believe that there is a grass tutorial on Twilight forum (maybe by Fletch). It is viable in postpro. The result is realistic.
                  • ntxdaveN Offline
                    ntxdave
                    OK Finally some new images after spending a lot of time learning how to use the Skeatter plugin. Yjeu were rendered with Twilight Render V2
                    • ntxdaveN Offline
                      ntxdave
                      Scene 3
                      Sorry, I could not add this 3rd image to the previous post.
                      • ntxdaveN Offline
                        ntxdave
                        Scene 2 FIXED โ—
                          ๐Ÿ‘
                          • majidM Offline
                            majid
                            Very neat model and render!
                            • ntxdaveN Offline
                              ntxdave
                              Thanks guys. ๐Ÿ˜„
                              For some reason I made a lot of mistakes when learning how to use the Skatter plugin but I think it is a good plugin for putting vegetation in a SU model. It supports several render applications which allows you to put a number of instances of vegetation in a model without bringing SU to its knees when looking around in your model.
                              • ntxdaveN Offline
                                ntxdave
                                Majid - just for you..............
                                AIP-Majid
                                • ntxdaveN Offline
                                  ntxdave
                                  Majid, this is just for you.............
                                  Alphabet Inspired Sketch - Majid
                                  • majidM Offline
                                    majid
                                    WoW, I appreciate it... ๐Ÿ‘
                                    • ntxdaveN Offline
                                      ntxdave
                                      A little more progress in learning how to use the Skatter plugin. I added the SketchUp logo to the last model. ๐Ÿ˜„
                                      • majidM Offline
                                        majid
                                        Wonderful!
                                        • majidM Offline
                                          majid
                                          Just realized that I have dropped some of my initial sketches and so they are not included in the book. So I thought it would be nice to share them here.
                                          Letter B- Dropped
                                            ๐Ÿ˜Ž
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 6 / 11
