    Exporting from SKP to DWG error
    10 Posts 3 Posters 802 Views 3 Watching
      Bruce Watt
      Hi All,
      I have a real issue here. I have sent my exported DWG from Sketchup to a consultant to work on. He has come back to me with drawings that are completely dimensionally wrong. At first, I could not understand this until I checked the SKP export in Autodesk DWG Trueviewer 2022 that I had done. Can someone please confirm my findings from the attached files.
      I have contacted support on this matter but would appreciate knowing if anyone else can see the issue.
      All the best
      The attached is a ZIP file which shows the SKP, DWG and a PIG screen shot
      SKUP PRO 2021 latest version / update
      Windows 10 Pro
      Dell Alienware Aurora R10 AMD
      AMD Ryzen™ 9 3900X
      NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
        I can confirm your exported .dwg reads...
        https://i.imgur.com/KfNgf9S.png
        If I export your .skp to .dwg using the default .dwg export options...
        https://i.imgur.com/cjosyRL.png
        I get 700mm...
        https://i.imgur.com/GbwIeDq.png
        So what are your export settings?
          Bruce Watt
          Thanks Rich,
          I am using 2D export default settings and have tried Autocad 18, 13 release 14 and 12 and still get erroneous results in the dwg. I tried the 3d export too and still get errors.
          I have tried a fresh file and just drawn some rectangles to test it out, and all works fine, so it's local to just this file.
          I have used the unwrap and flatten faces plugin on this file and wondered if a plugin could affect the output in this way.
          Very strange.
          Windows 10 Pro
          AMD Ryzen™ 9 3900X
          • BoxB Offline
            Are you using a Standard View (top, front etc) and Parallel Projection.
              Bruce Watt
              Thank you for your reply.
              I have tried them all.
              All the best
              Windows 10 Pro
              AMD Ryzen™ 9 3900X
              • BoxB Offline
                Just out of curiosity, see if this is the right size.
                Test exportBox.dwg
                  Bruce Watt
                  Yes, it is correct. ?
                  All the best
                  Windows 10 Pro
                  AMD Ryzen™ 9 3900X
                  • BoxB Offline
                    Then I think you have missed the point of my question.
                    Exporting an image or even a model from sketchup uses the camera view settings. So effectively what you see is what you get. (wysiwyg) Hence my question, are you using a standard view and parallel projection.
                    In your case it needs to be standard view top and parallel projection. This aligns the geometry you are exporting with the view that it will export. If you are not looking straight down on it it will not be the correct size.
                    So all I did was set your model to Standard View Top and Parallel Projection and then export the dwg which you found to be accurate.
                      Bruce Watt
                      Hello Box All,
                      Yes, I did completely miss the whole point of reality and of course parallel projection. A complete and utter brain fart, I am embarrassed to say. Thank you for your patience and help, but again total total user error. I feel so stupid. 😳
                      All the best 😳
                      Windows 10 Pro
                      AMD Ryzen™ 9 3900X
                      • BoxB Offline
                        You're not the first and I'm sure you won't be the last. This is a very common mistake.
