    Followme tool help Fredo courbette
    4 Posts 3 Posters 3.4k Views 3 Watching
    • B
      Bluewater77
      Hi, I'm new to drawing with Fredo app and cures/splines in general. Can someone give me some insight as to why I can't get a proper followme along the entire path? Thanks!
      followme test-2.skp
      followme test-1.skp
      • BoxB
        Scale! the geometry of the arc is too small for follow me to be able to make the faces.
        If you scale the geometry up by a factor of ten it will work, and by using what is known as the Dave Method, you can use a scaled version to edit the original.
        • B
          Bluewater77
          Brilliant! Thanks man!
            It looks like this...
            https://media.giphy.com/media/3ohs7PbCZTx1NekQOQ/giphy.gif
