    Warning before a component is edited
    3 Posts 3 Posters 7.2k Views 3 Watching
    • P
      pipingguy
      We should be given a pop-up warning if we are about to edit a component - especially in a large model. Glancing at the Entity info inspector panel does not work well because the top of the panel is sometimes obscured and would therefore take an action to reveal it. And even if it's un-obscured, just glancing takes time when you are focused on the work at hand. If I edit a component without knowing it has copies elsewhere in the model, it creates a huge problem.
      • BoxB
        There was a plugin made for people that have this problem with their workflow.
        https://sketchucation.com/pluginstore?pln=CoastalConcepts_EditFlag
        • TIGT
          EditFlag has an issue with newer versions' stricter Ruby.
          I posted a fix here:
          http://sketchucation.com/forums/viewtopic.php?p=670883#p670883
          which addresses it, but it does mean editing its RB file !
