    A plugin to change the color of all lines?
    5 Posts 2 Posters 2.4k Views 2 Watching
      jteselle
      Wondering if there might be a plug-in that would change the color of all lines (including in groups and components) to a chosen color (black in my case).
      I usually work in lines "all the same" color mode (black) but I want to change the color of a few lines now in a model. Problem is, when I switch to line color "by material" some of the lines in various groups and components are black, and some are other colors. It's a big model and going into each group and changing the lines to black would be a lot of work.
      Any suggestions? Thanks!
        What version of SketchUp? Please complete your forum Profile.
        There might be an extension that will work but it depends on the answer to the version question.
          jteselle
          I am using SketchUp 2022.
            Ah, good. And thanks for completing your profile.
            So with that in mind, how about Materials Tools by ThomThom? You can remove materials from just the edges in the model.
              jteselle
              Many thanks! That does the trick. I much appreciate your help.
