Roundcorner is not working
Hello guys,
Im new to the platform so i just want some help with a plug-in "Roundcorner". I downloaded the "free trial", but when i installed for the first time a message pops up and says "Trial period has expired since Fri 04 Mar 2022". Now I'm thinking its true the free trial or is a normal problem.
PD: I followed all the installation steps.
Regards,
Did you also install the latest Lib Fredo needed by the tool as a helper, and the latest version of SketchUcation Toolset v4.2.6 needed to properly checking its licensing ?
These are both needed for it to run...Restart SketchUp after the extensions are all install and retry...
If you have has the extension install previously, even if you have never used it, then its 'trial' date runs from the first installation, not its first use...
Register LoginAdvertisement
