    ClothWorks slow or freezing
    17 Posts 3 Posters 5.2k Views 3 Watching
    • H
      hallesy
      Hi, I have an issue with paid version of ClothWorks. When self-collide is activated, the simulation runs painfully slow or freezes. I have attached link below to a video showing issue. I have the latest version & the latest version of Sketcucation tools. It is the same story with Invidia & integrated graphics. If i try to make a pillow & follow the manual to the tee, it is also the same. I have uninstalled & reinstalled 3 times.I am hoping someone can help as tried everything within my knowledge base. Thanks in advance.
      Amazon Photos
      (www.amazon.co.uk)
        What's the density of the mesh? Self collision on a dense mesh is lots of calculations
        • H
          hallesy
          Hi, the density is 3000 which is recommended & also as many tutorials.
          • H
            hallesy
            Not sure how to reply as first time on forum, hope this is the correct way... the mesh is 3000 as recommended. Thanks
              What's your PC specs?
              • H
                hallesy
                Intel® Core™ i7… 16 GBram… NVIDIA® GeForce RTX™ 3060… GPU 6 GB GDDR6 dedicated… 8 cores, 16 threads).
                  OK, so you have plenty of grunt. Can you share file?
                  • H
                    hallesy
                    Yeah… proper sorted re hardware & wondering if that might be part of the problem? File attached but literally a simple box as collider & a simple plane as cloth for experimental purposes so doubtful it’s a model issue. Cheers for your time on this, Rich.
                    Clothworks test.skp
                    • A
                      Anton_S
                      This is interesting. I found the issue with a code change. An update will be posted very soon.
                      Thanks,
                      Anton
                      • H
                        hallesy
                        Hallelujah. Would you be kind enough to post on this thread when update ready please?
                        • H
                          hallesy
                          Just read email… thanks Anton.
                          • A
                            Anton_S
                            Hi Neil, an update has been posted. Please update to the newer version. Let me know if this one works as it should. Once again, sorry for the inconvenience this may have caused!
                            • H
                              hallesy
                              Hi Anton. I'm revisiting this post as recently needed this extension but issue unresolved. Clothworks will not work as supposed to. The simplest cloth rectangle with simplest box collider (following your manual to the tee) freezes sketchup & need to close in task manager. Please help with this issue as paid for extension that cant be used... thanks in advance.
                              • H
                                hallesy
                                P.S. have uninstalled & reinstalled but no difference!
                                • A
                                  Anton_S
                                  I re-downloaded the model you attached. I noticed the gravity is set to zero. Can you change it to 10? When I change it to 10, the cloth drapes the table properly. See attached picture (I also reduced bending stiffness since it looked to stiff). Also please verify the version of your clothworks. You can go to (Menu) Extensions->ClothWorks->About. It should be 1.7.7a
                                  Let me know.
                                  Thanks,
                                  Anton
                                  • H
                                    hallesy
                                    Thanks as always, Anton. I have input as your calcs & working much better. I'm pretty sure this is a user error problem but I seem to be getting there.
                                    • A
                                      Anton_S
                                      Neil, Let me know if the issue comes back. Thanks, Anton
