    Select component on a same z coordinate
    3 Posts 2 Posters 2.4k Views 2 Watching
    • S
      simorissette
      Hi everyone, newbie in the forum, thanks for your kindness.
      I would like to select components that are on the same z coordinate and then adjust their position all at once. Is that possible?
      Thank you
      S.
      • TIGT
        You need to use some Ruby...
        e.g. https://sketchucation.com/forums/viewtopic.php?f=323&t=20633
        • S
          simorissette
          Hi TIG, thanks for the orientation.
          Since I am a neophyte in sketchup programming, I will need more a step by step help. If you could give the code to copy in ruby and specify where to put the Z value to select component.
          Is it made for edges or faces selection only or a whole component can be selected.
          Does it select all components above or under the Z value or the component that are on this coordinate?
          Thanks for more information, sorry not to catch at first pitch!
          S.
