    Component Finder deleted my files
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    2 Posts 2 Posters 17.4k Views 2 Watching
    • E
      elsantoelcavernariobluedemonyelbulldog
      Hi, i was just getting started with the free version of component finder.
      i tried to add my file libraries to have easier access to the components and while using it all of the directories got deleted. idk if this is a common issue.
      i lost a ton of info and i want to know if maybe they are hidden somehwere, im scared.
      • halroachH
        halroach
        Hmmm, it's the first we hear of this. The only way folders can get deleted from within ComponentFinder is if you specifically right click on a folder in one of the open tabs and then select to delete it. There will then be a warning, asking if you're sure.
        Can you send me your log files located at: C:\Users%USERNAME%\AppData\Local\F3d_FlexTools\logs
        Please send as a zip through the contact form at: https://flextools.cc/contact
        FlexTools - Super Quick Windows, Doors, Slats...
