Fredo6 Animator
I'm using Fredo6 Animator and trying to move objects. I want to use the translation tool with "OutExponential" easing tool. When I use this easing method, the objects I move stop a little short of where they should (photo below). However, when I switch the easing to some other options (for instance "OutPolynom" also attached below), the objects move to their correct location. The only thing I have changed between the two photos below is the easing option. Does anyone know what I'm doing wrong?
Thank you!
Difficult to find out from the pictures.
I tried on a simple model (attached), and I cannot reproduce the problem
Maybe the best would be that you send me the model.
Fredo
Register LoginAdvertisement
