    Simple plugin Request: Export list of materials used.
    6 Posts 3 Posters 3.6k Views 3 Watching
    • R
      ramonbastos
      Hello! Im searching for someone who can make me a plugin, of course I'll pay for that.
      What I need is to export in a csv file all the materials used in the model. The same ones that shows on the "In model" list. Thats it. Just the names, no need for area etc.
      • TIGT
        Sounds like a simple job...
        Do you want the materials loaded into the model, OR the used materials in the model ?
        Different things...
        How do you want the materials listed ?
        e.g. by 'display_name' or something else ?
        You don't want areas etc.
        What will you use the list for ?
        CSV file seems unnecessarily complicated - a simple text file as a list might suffice ?
        Do you want this list 'sorting' alphanumerically ?
        • TIGT
          Try installing this...
          TIG_Materials-name-list.rbz
          • R
            ramonbastos
            Wow, TIG himself answering me, you're a legend dude haha. The rbz you sent is exactly what I needed! Answering what you asked:
            The way you listed is perfect, pretty simple and straight forward. Is it possible to list by the area? For example, material A is used in 1sqm, material B in 2sqm and material C in 0,5sqm. So the list is:
            B
            A
            C
            Basically I need to know wich materials I used in each model, to organize them.
            xlxs like you did is perfect.
            No need.
            EDIT: How can I pay you?
            • R
              rv1974
              You could open material browser and set it in a ListView (sorted alphabetically BTW), do you really need a plugin specifically for this?
              @TIG, What indeed would be super useful is to get a grid of tiles (say 100x100 cm) with material samples taken from selection, (or, as alternative- globally). the tiles should be accompanied by text(see attached) indicating the material name. The goal is to use TT's material replacer plugin afterward to purge parasitic materials with a parent one (i.e. glass<1>, glass<2>.. will be replaced with glass).
              https://sketchucation.com/pluginstore?listtype=1&author=0&category=0&search=material+replacer&submit=%3F
              This is what I do manuallybefore exporting models further to other DCC's.
              NB! It's important to have an option to output from selection.
              • TIGT
                Does something like this do that ?
                https://sketchucation.com/pluginstore?pln=material_browser
