    Got Balls ?
    16 Posts 8 Posters 4.2k Views 8 Watching
    • tuna1957T Offline
      tuna1957
      I made you look didn't I πŸ˜† . Nothing impressive to see here. Have a billiard room model / render sloshing around in my head... started modeling up all the bits and pieces I'm going to need. Here's the billiard balls. Simple to make you say.. Can't disagree until you start putting the stupid numbers on them. Not hard to do but damn is it tedious. Was ready to stick a pencil in my head by the time I was done. Raw SU view of my "balls" and a quickie Twilight render checking my texture set up.
      • Bryan KB Offline
        Deceptively simple, yet elegant. πŸ‘
        • HornOxxH Offline
          HornOxx
          Ja !!! πŸ˜† πŸ˜† (nice render!)
          never trust a skinny cook
          • pbacotP Offline
            nice balls! Can you explain how you put the numbers and stripes on?
            • tuna1957T Offline
              tuna1957
              Thanks guys. I'm wondering how many people my title will trick into seeing my silly little post. 😎
              pbacot , Set up the process and saved an image for you. Hope I made the various steps clear enough. Once you have the "spot" marked on the ball it's just a matter of copy the ball right and aligning it with the cylinder. I find setting up the cylinder to align the numbers on easier for me to get them centered properly. One big thing don't forget to make the ball unique every time you copy it. If you don't it will gum up the works. Ask me how I know πŸ˜† . "Quad Face Tools" makes selecting the "rings-loops" ( can never remember which is which ) easy. The " copy - scale" is a must or your certain to end up with holes to fix. Takes way longer to explain than do, just tedious and repetitive.
              • HornOxxH Offline
                HornOxx
                πŸ‘ great!! all done with pure geometry and not with some "substance painter-uv-mapping-trick" which I would never grasp anyway πŸ˜„ πŸ˜„ πŸ˜›
                @tuna1957 said:
                ...I'm wondering how many people my title will trick into seeing my silly little post. 😎
                with a title like that you have my visit - always !! πŸ˜›
                • Bryan KB Offline
                  Thanks for sharing the technique! πŸ‘
                    Very nicely done. πŸ‘
                    • tuna1957T Offline
                      tuna1957
                      Thanks HornOxx 😎
                      • tuna1957T Offline
                        tuna1957
                        Bryan ,Mike thanks πŸ‘
                        • pbacotP Offline
                          Good job on the technique!
                          • G Offline
                            garystan
                            tuna1957 :
                            Nice render.
                            garystan
                            • tuna1957T Offline
                              tuna1957
                              pbacot , garystan , thanks much.
                              • hellnbakH Offline
                                hellnbak
                                Nice render and technique. I like it when someone goes to the trouble of sharing their modeling methods πŸ‘
                                I used a similar title - Playing with my "Thing" - when I posted my VW Thing a while back. Was actually a little hesitant about doing that, you never know who you're gonna offend nowadays. I did wimp out and put Thing in quotes tho
                                Nicely done
                                • utilerU Offline
                                  utiler
                                  lovely render tuna1957, which program do you use?
                                  Just Curious...
                                  • tuna1957T Offline
                                    tuna1957
                                    Thanks utiler, I render with Twilight V2 Pro. 😎
