    File Output for 5-Axis CNC Machining?
    4 Posts 2 Posters 9.8k Views 2 Watching
    • E
      EzekielK
      Got an Art Director asking about using sketchup geometry to drive a 5-axis CNC machine. Have found apps advertised for preparing SU files for the purpose but the process looks torturous and so far as I know SU is not a favored tool for the modeling -> CNC pipeline.
      Does anyone have recommendations for a process that works well for moving sketchup geometry over to the CNC side, and/or any typical constraints or difficulties encountered in doing that?
      Thanks in advance.
      K
        Did you look at SketchUcam?
        https://github.com/swarfer/sketchucam/releases
        Did you try Freecad to Gcode Export? Or are you dealing with SKP files primarily?
        • E
          EzekielK
          everything is starting as skp files
            Only one I knew is SketchUcam. Sorry, not much else to add.
            SketchUp is a poly modeller so TRUE curves aren't possible. You will always fight against segments causing facetting.
            I believe SketchUcam's extport to g-code was quite adequate on flat sheet cuts. But 5-axis stuff could be a bit of a stretch.
