    Remove softening
    7 Posts 4 Posters 4.9k Views 4 Watching
    • CrealC
      Creal
      Dear all,
      Here is my questionning,
      Is there any way or tool to remove softening of multiple segments at the same time?
      I checked and it seams only possible to remove softening of a segement one at the time with a right clic.
      Damn it is so laborious 😠
      A great thank for the one who will helps me in this matter.
      C.real
      • BoxB
        You need to show us what you mean, what you want to do.
        But basically, yes with the soften smooth dialog in the default tray.
        • CrealC
          Creal
          Yes you're right, you need more details for answering me sorry.
          I just would like to choose some specific segments already softed and unsoft them at the same time.
          Soften smooth dialog apply this action but in global and not the way I want.
          By the way, thank you really for this quick answer πŸ˜‰
          C.real
            Why not use the Erase tool with CTRL/ALT modifier to apply or remove as needed?
            It's always gonna be manual though or slider based.
            • BoxB
              It would still help to see an example of what you are wanting to do.
              Is it possible you just need to turn on hidden geometry so you can work on parts and then turn it off again.
              • Jean LemireJ
                Jean Lemire
                Show hidden geometry to reveal softened edges.
                Select as much as you can with a window select.
                Use the Soften/Smooth Window and then move the cursor to the leftmost position. All selected edges will be unsoftened.
                • CrealC
                  Creal
                  Thanks for your reply
